bpz1970
Sound coming simultaneously from earpiece and loudspeaker
Sat Feb 01, 2020 4:37 pm
Hello. My BV9500 Pro is releasing, since some months ago, the sound from both speakers (earpiece and rear loudspeaker) while it should only come out from the rear loudspeaker. While making a regular call, there's not a problem, the earpiece works fine and the proximity sensor too. The problem is coming while listening to music or watching a video, the sound is coming from the earpiece and the loudspeaker at the same time, like as if it'd be stereo mode. I can't modify this output from the Configuration. Does anyone have a clue about it?
Re: Sound coming simultaneously from earpiece and loudspeaker
Mon Feb 03, 2020 8:09 am
You can have a try to reset the sound: Go to the dial interface and dial "*#87#".
Or you can contact our professional after-sales directly.
bpz1970
Mon Feb 03, 2020 5:01 pm
Hello. Thanks for your fast reply. Unfortunately, once I dial *#87# nothing happens, it's not taking me to any menu or action. Are you sure that's the right ussd code?
Tue Feb 04, 2020 5:20 am
Hi.
I so sorry the code can not help you. The code is our after-sale colleague teach me.
I think you'd better contact our professional after-sales directly.
Have a nice day!
