Sauron
FLIR
Mon Jan 27, 2020 5:13 pm
My FLIR app says: u able to read camera files. What shall i do?
Re: FLIR
Fri Feb 21, 2020 7:36 am
Sauron wrote:
More detail?
rydyk
Re: FLIR
Sun Mar 01, 2020 5:40 pm
Mi phone sens the dame error, all sensor its ok, in the test whit *#87#, thermal image exist , i reinstal the rom. Error persist.
spinne
Re: FLIR
Mon Sep 07, 2020 8:58 pm
I'm going to hijack this thread, because I have the similiar situation
so far the folowing things have been done to ensure a working thermal camera:
 - update to the available stock rom from https://bbs.blackview.hk/viewtopic.php?f=285&t=532354 with the flashing tools:
 -> SP_Flash_Tool_v5.2028_Win
 -> SP_MDT_exe_v3.1836.00.01-A2018.11.06-v1.0-custom
- update via OTA to new version BV9800Pro_EEA_S65_V1.0_20191113V1
- reset to factory defaults via vol+ and power button before boot
- reset to factory defaults via *#87# and password
- cleared storage of MyFLIR app
- cleared cache of MyFLIR app
- all app permissions for the app were granted (camera, location, microphone, phone, storage)
- IMEI1, IMEI2 and MEID were restored with tool SNWriter_1924-4.2.0-up-1.2.0-vturkey
In factory testing mode (via dial *#87#) the thermal camera is working (i get a black&white image). The MyFLIR app won't work. A message appears "unable to read camera files" after that the app closes.
best regards spinne
cnorman27
Re: FLIR
Wed Sep 23, 2020 6:25 pm
Spinne,
I had the same exact issues as you. Have you been able to fix the problem yet?
Chris
Re: FLIR
Thu Sep 24, 2020 6:02 am
cnorman27 wrote:
Spinne,
Chris
What problems?
spinne
Re: FLIR
Thu Sep 24, 2020 9:30 pm
blackview_admin wrote:
cnorman27 wrote:
Spinne,
Chris
What problems?
So its a normal behavior, that the MyFlir App doesnt work, even after clearing the app Cache? I have attached a video which describes the problem, that no thermal image is generated by the app.
cnorman27
Re: FLIR
Thu Sep 24, 2020 10:47 pm
cnorman27 wrote:
Spinne,
Chris
What problems?
I installed the latest rom from viewtopic.php?f=285&t=532354 and now the MyFlir app won't work.  When I try to start it, it has a dialog that pops up and says "Unable to Read Camera FIles".
I e-mailed support and their response was to "Clear data and restart the app".  I've done that several times and the app still does not work.
I bout the phone specifically for the Thermal Camera and the app wont' work.  How do I fix it?  What Camera Files is it looking for?
spinne
Re: FLIR
Sun Sep 27, 2020 9:39 am
that is the problem.
spinne
Re: FLIR
Mon Sep 28, 2020 8:22 pm
cnorman27 wrote:
Spinne,
Chris
What problems?
https://www.youtube.com/watch?v=XF3I2UqabTc  This Problem
