yesterdayze
Latest ROM will not flash
Mon Jan 27, 2020 5:08 pm
Hi, has anyone had any luck with the latest (about 3 weeks old now) ROM for the BV9800 Pro? I have tried numerous times to install it to no avail. Could anyone give me any pointers?
I have put a brand new sd card in. Formatted it as external storage. Downloaded the ROM to it using my computer as well as using the MEGA download app. In both cases it downloads fine. I then go to settings->system->advanced->about phone->wireless update and use the 3 dot menu on the top right hand to tell it to do a local update. It reboots, shows the spinning update, then fails.
When I checked the logs I see a bunch but the most pertinent seems to be the following:
[    0.000095] __bionic_open_tzdata: couldn't find any tzdata when looking for Europe/London!
[    0.000122] Starting recovery (pid 305) on Mon Jan 27 17:01:15 2020
[    0.035922] cannot find/open a drm device: No such file or directory
[    0.035961] fb0 reports (possibly inaccurate):
[    0.035965]   vi.bits_per_pixel = 32
[    0.035968]   vi.red.offset   =   0   .length =   8
[    0.035971]   vi.green.offset =   8   .length =   8
[    0.035974]   vi.blue.offset  =  16   .length =   8
[    0.072846] framebuffer: 0 (1080 x 2340)
[    0.102646]           erasing_text: en (137 x 57 @ 2030)
[    0.108376]        no_command_text: en (249 x 57 @ 2030)
[    0.113026]             error_text: en (99 x 57 @ 2030)
[    0.503200]        installing_text: en (459 x 57 @ 2030)
[    0.555584] SELinux: Loaded file_contexts
[    6.738319] Verifying update package...
[    6.929150] E:footer is wrong
[    6.954112] Update package verification took 0.2 s (result 1).
[    6.971724] E:Signature verification failed
[    6.989233] E:error: 21
[    7.009698] W:failed to read uncrypt status: No such file or directory
Re: Latest ROM will not flash
Sat Feb 22, 2020 9:34 am
Your flashing ROM is not correct.
You can learn form this post: http://bbs.blackview.hk/viewtopic.php?f=17&t=532865
