TechnoMan
Root on BV9800 Pro
Sat Jan 04, 2020 5:18 pm
How can I get root access on a BV9800 Pro phone?
I understand about removing the phone from the warranty and do not claim after gaining root access to the warranty. But many programs do not work for me without root access, and I really need them.
Re: Root on BV9800 Pro
Tue Jan 07, 2020 6:28 am
We can not help you to get the root on the phone.
Is there anyone can help this topic author?
sams
Tue Jan 07, 2020 12:43 pm
you can root it with Magisk :
Download your rom from : viewtopic.php?f=285&t=532354 (you can alternatively extract it with SP Flash Tool and WWR)
Download and install Magisk Manager on your phone : https://github.com/topjohnwu/Magisk/rel ... v7.5.0.apk
Patch the boot image with Magisk Manager
Unlock the bootloader. (Wipe the phone! )
Flash the patched boot image with SP Flash Tool or Fastboot. (ONLY the boot image)
Reinstall Magisk Manager
MedievalKing
Fri Jan 17, 2020 8:17 pm
How do I know if I have EEA Version for ROM download or the non-EEA version?
BV9800 Pro user
nris
Tue Jan 21, 2020 1:23 am
sams wrote:
Hello, can you explain with more details and links to tools? Thank You,
Btw, once i download the official rom how to update?
Wovenfiber
Mon Jan 27, 2020 8:49 am
I can't find a USB driver for this bv9800pro. What USB driver did you use?
nris
Wed Jan 29, 2020 7:03 pm
sams wrote:
Hello, can you be more specific about how to root it? Also how to update the rom from viewtopic.php?f=285&t=532354 ?
sams
Tue Feb 04, 2020 11:54 am
Check you build number in "About the phone"
sams
Tue Feb 04, 2020 12:02 pm
https://developer.android.com/studio/run/win-usb
https://adb.clockworkmod.com/
Or you can just STFW for MT6771 adb drivers...
sams
Tue Feb 04, 2020 12:16 pm
You don't need to update, your phone was shipped on this version. You only need this file to get the boot image and the scatter file.
There is a LOT of tutorial all over the Internet for each step. You can also use viewtopic.php?f=247&t=476742 for reference.
