WSGolem
Noise when using wired Headphones
Wed Nov 27, 2019 12:36 pm
With the included wired headphones, I often hear loud noise, a loud crackling, even my interlocutor can not understand me because of these sounds. The same thing happens with other headphones, but not when paired via Bluetooth. a loose contact or plug problems are eliminated, the problems are synonymous, without moving the cable. Someone an idea what causes these sounds?
WSGolem
Re: Noise when using wired Headphones
Fri Nov 29, 2019 8:04 am
I've found that the glitches do not occur when mobile data is disabled. So the phone interferes with the wired headphone operation by receiving or sending mobile data. I do not think this can or will be fixed by an update. Looks like a design error.
Pizzalover
Fri Feb 14, 2020 1:35 pm
Quick reply:
I haven't used the included earplugs, but my QKZ in-ear monitors does not pick up any noise. Could it be inefficient shielding of the cable?
