grAwp
Android Recovery - cant load Android system
Sun Nov 24, 2019 9:52 am
after one year normally wear of phone I turned on in morning and I have problem to run it - Android Recovery - cant load Android system, data may be corrupt. I tried turning off the phone, and unplug and plug back the battery from phone.
Is there some software which can fix or repair corrupted Android data. I must save all the photos before Factory reset.
Can you somebody help to me ?
Thank you
