drg76
Android 8.1 patches
Mon Oct 14, 2019 10:05 am
I understand that Android 9 will not be available for the P60 version of the BV9600 Pro but can we at least get security updates for Android 8.1 ?
Re: Android 8.1 patches
Tue Oct 15, 2019 8:39 am
Yes, our team have made an OTA schedule of the BV9600Pro
lokiyo
Tue Oct 15, 2019 9:13 am
So basically it's confirmed we've been lied to and no 9 for P60 original supporters?
Jack-212
Tue Oct 15, 2019 9:32 am
What is the scheduled date?
taz22
Tue Oct 15, 2019 1:34 pm
THANK YOU for your patches
why do not we have the update for android 9?
Neville
Wed Oct 16, 2019 10:49 am
Because the P60 hardware and components were fine-tuned to run on Android 8, and manufacturers are fast learning that it is impossible to guarantee hardware configurations can run future Android versions that exceed the parameters of the configuration the phone was built to.
If Blackview could safely upgrade your P60 to 9 without bugs they would have done so.
inetdude
Wed Oct 16, 2019 11:27 am
That's silly! The P60 wasn't built only for BV! There are a lot of other P60 phones from other manufacturers - here a list as example:
https://www.kimovil.com/de/liste-smartphones-nach-prozessor/mediatek-helio-p40-mt6671
and a lot of them are running Android 9 (Pie) - here also an example for one ot them (scroll until the end of webpage to see the software version):
https://www.kimovil.com/de/wo-kaufen-cubot-x20-pro
BV is not willing to update the "old" bv9600pro - you have to buy again (the new one) to get Pie!!! Not with me... :-(
Jack-212
Fri Oct 18, 2019 2:02 pm
The upgrade is expensive ...to do it and to test it.
tommo
Sun Oct 27, 2019 6:44 am
I have been running Android 9 on my bv9600 pro for a month and it is perfectly stable with exactly the same bugs as 8.1
So think again.
Jack-212
Wed Oct 30, 2019 3:13 pm
I have bought a Samsung smartphone and  a Huawei tablet, both of them have been updated very quickly to Android 9 ; moreover they have been patched many times for security patches ...
This is how a product is well supported !!
