silvietta
keyboard change suggestions
Tue Oct 01, 2019 9:22 am
Hi all,
I'm a new BV9500 user, coming from a 5 years of great BV6000 Pro usage and I've a silly question about keyboard in BV9500: when I was writing on BV6000, everywhere, from WA to terminal, as soon as keyboard came up I got a notice in upper bar allowing me to change keyboard itself (from gboard to android native keybd, to terminal keybd, to voice); now on BV9500 I'm allowed to change keybd (e.g. for getting voice keybd) only by disabling every other keybd than the one I want to use, and that's annoying. There is a way to get change keybd notifications on BV9500 too?
Thanks,
Sil
bvbw
Re: keyboard change suggestions
Wed Oct 02, 2019 6:52 am
Hi Sil,
Before the 9500 Plus i had also a BV6000 and there is no difference for switching the different keyboards with notification bar.
More, there is also a keyboard button at the bottom right of the screen in the navigation bar when your first keyboard is used.
Hope it help ...
silvietta
Fri Oct 04, 2019 9:31 am
ok thanks ... I don't see any keybd changer nor in notification bar (as in bv600 was) neither in bottom right unless the globe icon that doesn't report, anyway, any voice input, just IT-FR-EN FR-EN-IT and so on but I have been right today in need to add Pinyn Chinese keyboard and in Pinyin kbd finally I've found voice button!
Maybe is a bit complicated, switching from italian to pinyin for getting voice button but anyway it works! :D
Thanks,
Sil
bvbw
Fri Oct 04, 2019 9:55 am
If you make long press on the space bar of the GBoard keybord, what happen ?
