Problems:
1) Bad signal, continuously goes from 4G to 3G. Calls are cut at 2 or 3 minutes.
2) m[color=#222222][font=-apple-system, Helvetica Neue, Roboto, Segoe UI, Helvetica, sans-serif]ost of the photos are moved. All faces disfigured. A miracle take a good picture.[/font][/color]
[color=#222222][font=-apple-system, Helvetica Neue, Roboto, Segoe UI, Helvetica, sans-serif]3) f[color=#222222][font=arial, sans-serif]rom what I read it has defects everywhere.[/font][/color][/font][/color]
Can you help me?
Version
Band Base: MOLY.LR12A.R2.MP.V61.22
NUCLEO: 4.4.95 (GCC VERSION 6.3.1 20170109 (LINARO GCC 6.3-2017.02)
COMPILATION: BV_BV9500_V1.0_20190302
PERSONALIZE: APLS-MP-O1.P1
Best Regards,
Eduardo
Rosario, Sta Fe, Argentina.
