udolini
How to root BV9600??
Tue Sep 24, 2019 6:56 am
How to root my BV9600? I would like to activate camera 2 api.
JPRMB
Re: How to root BV9600??
Thu Sep 26, 2019 3:06 pm
I want the same with my 10000 pro And my bv 9700 pro. Many apps doesn't work !!
Headdestada
How to root BV9600
Fri Sep 27, 2019 10:26 am
In my opinion, it is an interesting question, I will take part in discussion.
frofa
Sun Sep 29, 2019 12:55 pm
0. Download ADB and install drivers on your Windows computer
1. Unlock the bootloader
2. Flash TWRP
3. Install Magisk
Works perfectly well on my BV9600.
prokhor.ozornin
Sun Sep 29, 2019 8:08 pm
2. Flash TWRP
3. Install Magisk
Where can we find TWRP build for Blackview phones? twrp.me website does not contain it.
frofa
Thu Oct 03, 2019 10:00 am
download TWRP for BV9600pro, which also works for the BV9600EEA (not "pro"), from here: https://download900.mediafire.com/js0hqv9axn1g/2p2ek019reu7ek6/Blackview+BV9600+Pro+twrp.rar
Flash it, then immediately boot into it (otherwise TWRP will be automatically overwritten), and flash Magisk. Then, your phone is rooted. Like most available TWRPs, this one has a problem with encryption in Android 9, so you can boot into it once and use it. Later it will require a "password", but won't accept your correct password for decryption - that's a bug in TWRP. There are some newer versions for other phones, but not yet for the BV9600, unfortunately. But it gets the job of rooting done, that's the important point!
