Nicolas
the light goes out when the battery is less than 15%
Sat Sep 21, 2019 12:43 am
the light goes out when the battery is less than 15%, can we adjust the light cutoff threshold
Re: the light goes out when the battery is less than 15%
Sat Sep 21, 2019 7:01 am
No, but you can charge it.
Mike!
Sat Sep 21, 2019 7:14 am
By default the phone activates energy saving mode when battery drops to 15 %. So you could deactivate energy saving mode. By the way, what light are you talking about?
carabao
Sat Sep 21, 2019 7:38 am
the brightness of the screen, no. But the threshold (percentage) of the trigger.
You can lower the% from which the economizer triggers.
Path: setting, battery, battery saver
The% is adjustable from 0 to 100%.
Nicolas
Sat Sep 21, 2019 3:43 pm
I'm talking about the back light, with the flashlight. Thank you all
Nicolas
Sun Sep 22, 2019 10:45 pm
I talk to the flashlight, the rear light.
nicow
Tue Sep 24, 2019 9:04 pm
Is it possible to change it.
I would like to be able to use flash light when I want even if the battery is less than 15%.
Thansk
Mike!
Sat Oct 05, 2019 8:46 am
Solution is the same. Deactivate energy saving mode or set it to be activated at 10 % or 5 %.
Or - best solution - keep the battery above 15 %.
There is no possibility to adjust only the LED light.
