opv.yulo@gmail.com
W1 wireless charger
Wed Sep 18, 2019 7:51 am
From the BV9500 plus ad, it said 7 hour on the 5V/2A normal charge. I am using Blackview pad (model:W1) and it was charged around 10% up in each hour. Then i can have fully charge in 10hour. Is this normal? Is this 10W fast charge or 5W standard charge?
If i were not wrong, fast charge 3.5 hour means adaptor 12V/2A + cable 24pin type C? The package adaptor is capable of 9V/2A but I don't know what the capable of the package cable? normal type C?
By using the package adaptor and a cable 24pin type C, it shall be fully charge in between (more than) 3.5hours and (less than) 7 hours, shalln't it?
If I want the fast charge on cable charge, Do adaptor 12V/2A and cable 24 pin Type C need to buy seperatly?
I am not good in electric system so please advice. By the way, I am from Thailand and here electricity is 220V basis.
Re: W1 wireless charger
Wed Sep 18, 2019 9:50 am
Thanks for your feedback, 5V/2A for cable charge. The wireless charger may lost some energy during charging. You can use the original cable and adapter in the package, it support 12V/2A fast charge.
