harvas81
Blackview lost IMEIs.
Sun Sep 15, 2019 8:42 am
Hello admin. I have upgraded via SPFlash tool the software of BV7000 Pro to the latest version v35.4.P7, 2017/10/25. I have used Format ALL + Download option, since the program instructed me to do so ("Download only" option was failing). After I have finished the flashing and booted the phone and after completed all necessary steps (Google account, Playstore, install apps, setc), I found out that I have invalid IMEI and the *#06# command produces null values (empty box).
I have read a lot about methods to recover the 2 IMEIs, but I couldn't fix it. For example, the GPRS method via Engineering mode fails to write the new IMEI.
I need the MD1_DB and AP_DB files for BV7000 Pro (MT6750 chipset), in order to use them with "SN Writer v1.1640" tool.
I have downloaded an archive called "mtk imei repair nvram db files", it contanins 16 MTKs rar files with DB files but unfortunately MTK6750 is not included.
Re: Blackview lost IMEIs.
Sun Sep 15, 2019 9:15 am
Enter *#*#8688#*#* to rewrite IMEI, then restart your phone.
carabao
Sun Sep 15, 2019 1:02 pm
Valid for other blackview smartphones?
Thank You
French version: viewtopic.php?f=280&t=531409
Mon Sep 16, 2019 2:25 am
Thank You
Yes, for  9600/9600Pro/6800Pro/5900/9100/A60/a60PRO
carabao
Mon Sep 16, 2019 7:55 am
It is modified, thank you
