Fruitmans
Unable to use NFC & FreeStyle Libre
Thu Sep 12, 2019 9:39 am
As a diabetic patient i use the Freestyle Libre glucose monitoring system. The sensor communicates through NFC and comes with an app for android phones. On my samsung phone it worked like a charm but unfortunately i am not able to get this working with the BV9600. How can i solve this?
Re: Unable to use NFC & FreeStyle Libre
Thu Sep 12, 2019 10:12 am
Can you offer me a video about how SAMSUNG works? we can analyze it in detail, cause we have never met that before, your video would be very helpful.
Fruitmans
Thu Sep 12, 2019 10:26 am
It is not my video but is shows exactly how it works:
https://www.youtube.com/watch?v=IxAFc_XaQFE
kekkoZ
Wed Oct 23, 2019 7:03 pm
I have the same problem with blackview 9700 pro.
sometimes it works like in the video. sometimes not find the sensor. however with nfc tag everything works correctly.
kekkoZ
Wed Oct 23, 2019 7:11 pm
[color=#222222]I have the same problem with blackview model 9700 pro.
sometimes it works like in the video. sometimes not find the sensor freestyle libre. however with generic nfc tag everything works correctly.[/color]
Olaf Kropp
Fri Aug 07, 2020 8:47 am
I have the same Problem with my nee BV9800pro. Is there anything that i can Provider with top solve this issue?
Cheers Olaf
Olaf Kropp
Wed Aug 19, 2020 6:17 am
I have the same Problem. My BV9800pro is not able top read my glucose values via NFC from freestyle libre Sensors.
Is there any way to solve this issue?
Fri Aug 21, 2020 6:10 am
Olaf Kropp wrote:
Sorry, our product doesn't support this function
Fri Aug 21, 2020 6:11 am
Cheers Olaf
ytsma
Wed Oct 14, 2020 11:00 am
i have An bv 5900 that alsof doesn't work. Can this be fixed with android 10?
