Neville
Vibrate not working?
Thu Sep 12, 2019 6:31 am
Has vibrate stopped functioning after update?
No vibrations now...is there an engineering mode we can test the vibrator?
Re: Vibrate not working?
Thu Sep 12, 2019 9:00 am
Try *#87#
Neville
Sat Sep 14, 2019 9:28 am
Tested: Fail. Vibrate no longer functioning.
Sun Sep 15, 2019 6:42 am
How about restart or factory reset?
carabao
Sun Sep 15, 2019 6:25 pm
hello,
The "vibration" function does not work on my bv9700pro either. And besides, the code * # 87 # is not supported.
Mike!
Sun Sep 15, 2019 7:06 pm
@ carabao:
Did you also install the update? Because if the update causes the vibration not to function anymore that's one more reason for me to not install it. Because for me vibration works fine (for now).
carabao
Sun Sep 15, 2019 7:16 pm
No, original version of my BV. See my signature
EDIT:
I am no longer certain that the vibration does not work but it seems to operate randomly. I'm testing
Mike!
Mon Sep 16, 2019 4:00 pm
The vibration of the BV9700 Pro is very weak and silent (compared to the BV8000 Pro which I had before), I also often simply do not recognize it. But it works for me.
