nicow
Micro sensitivity App Sleep Cycle problem
Mon Sep 09, 2019 9:33 pm
Cycle Sleep is not working well with the BV 9700 pro. I thinks micro sensitivity is too high (I test in a very quite place the native app sound meter and it's always around 28 db instead of 0).
the App Sleep Cycle use micro of the phone to analyse the sleep rythm.
When I compare Iphone and BV 9700 pro in the same time, the BV is too sensitive.
do you know where the engineerMode I can adjust the sensitivity of the microphone ? (Hardware testing / audio / volume / voice ?). Do i need restart the phone everytime I adjust a parameter ?
Thanks a lot,
Nicolas
Re: Micro sensitivity App Sleep Cycle problem
Tue Sep 10, 2019 6:17 am
[Settings-System-About Phone-Build number] click 4 times to enter the developer model. Enter  *#9646633# in the dialing interface to debug, and restart the phone verification after debugging.
Mike!
Tue Sep 10, 2019 4:45 pm
A quiet place is never at 0 dB. It's at around 30 dB so the 28 dB the phone shows you seem to be correct.
nicow
Wed Sep 11, 2019 12:42 am
Thanks,
What are the values I have to change to modify microphone sensibility ?
Best regards Nicolas
