prakasam
Phone fail to boot every three months once . must do factory data reset ( no other options )
Fri Sep 06, 2019 7:46 am
Hi Team,
this is the third time I faced this issue. phone was hanges. when I restart sometimes it was starting. but every three months once it fails to book again .. it was showing an option booting fail to try again of factory data reset. when I select try again for few times no use. and then I am selecting a factory data reset.  I am losing all my photos and files.
we don't know when it may happen to do back up first... after doing factory data reset phone working as normal.
prakasam
jang
Re: Phone fail to boot every three months once . must do factory data reset ( no other options )
Sat Sep 07, 2019 7:33 am
Had exactly same issue yesterday. Lost all files and photos.
aztec165
Thu Oct 10, 2019 8:47 am
Hello ,
i have the same problem..., i am really worried
what is the solution?
best regards
i use a BV6000 since the midlle of october 2016 , unstoppable phone !
prakasam
Fri Nov 15, 2019 3:49 am
blackview_admin wrote:
Hi, pls contact our tech team directly: https://store.blackview.hk/en/feedback
thanks for the info , I have contacted blackview .they suggested return the device for repair .. I send back to blackview factory ( china ) .. they have repaired and sent back the device.  now my mike echo voice problem was solved and Bluetooth and headset problem was solved  ..
I will wait for three months for check fail to boot the problem ..
prakasam
aztec165
Mon Feb 17, 2020 10:33 am
I meet the same problem ,
Last Rom problem ? 16/08/2019
Or smartphone problem?
Could i have more information ?
Best regards
Sebastien
