flthomas50
BV9500 does not start
Wed Aug 28, 2019 8:48 am
I bought BV9500 phone in November 2018, this phone no longer works and the reseller (website) by which I bought no longer exists also.
How can I make the warranty ?
[font=-apple-system, Helvetica Neue, Roboto, Segoe UI, Helvetica, sans-serif]the phone is stopped, the battery has heated and since it does not start anymore[/font]
Thank you for your reply.
Re: BV9500 does not start
Wed Aug 28, 2019 11:22 am
Hi, may I know where did you buy the phone? the seller's name?
For quality issue pls contact support02@blackview
