Woodman1974
Hard Bricked after install rom
Tue Aug 27, 2019 7:45 pm
my Blackview bv9500 is hard bricked after install rom.
Only the red light is on when i connect it. And it connect and Disconnect. I have tried some things, but it would not flash again.
Some user conncet the mother board with the test point. Have you got some infos to do itr back to life?
I use the sd flash tool. and fastboot.
Its a good mobile phone.
Thanks...
Woodman1974
Re: Hard Bricked after install rom
Wed Aug 28, 2019 5:47 am
thanks for the links. the video has no sound. i will try it.
and i think it very importent to install the correct driver without the driver signature.
Yamach
Sat Aug 31, 2019 4:42 am
Dear administrator after the last update my phone stopped working the speaker in calls and I just noticed that also the GPS. Send mail to the rom manager requesting info if this would solve my problems and how to install it as novelties of rom. Unfortunately I have not received an answer. I am very happy with my BV9500, it would hurt a lot to change it. Could you help me? I'm afraid to do something wrong and spoil my phone
Woodman1974
Sat Aug 31, 2019 9:37 am
My phone is back To LIFE. Thank you a lot. Great Work.
Best Regards
Avesremer
Wed Sep 04, 2019 7:13 pm
Hi there Im from South Africa and the OFT is not common here but I have one And our best fuel octane is 95 Ron can u help me with a link just to see if your tunes also ok for our fuel? Thanx
Avesremer
Sun Sep 08, 2019 10:49 am
Vitaluga
Wed Aug 19, 2020 4:10 pm
Hey. I have the same problem with my phone. Only the red indicator is on. Help, how did you restore it step by step? I get a memory error via flashtool. In the device manager, only mtk usb is visible.
