Hi
I've recently purchased a 9500 Pro, mainly to use as a communications device either with the Zello network App of the built in UHF radio.  I've been testing the radio on Ham Radio frequencies and it works very well, apart from one very annoying thing.  There seems to be an automatic transmit time-out programmed in for 30 seconds.  Whilst I can see the use for this to prevent accidental frequency blocking, there needs to be a method of changing the time limit.  30 seconds is way too short for most ham radio use, often in the UK we use 120 seconds for auto time-out on radio repeaters.  Is it possible for you to alter the App to allow a user selectable timeout please, this would make the 9500 Pro suitable for Ham Radio use, at the moment it really isn't.  There is also no indication to the user that the transmission has timed out, so you can just carry on talking - to nobody!
Cheers
Jon
