iceeci
bv9500 pro saying is rooted in apps when it is not
Sun Aug 18, 2019 12:44 pm
i have a bv9600 pro
it is saying that it is not rooted when i do a check but all my banking aps are saying that it is rooted
any way to restore it so they will work again
i have tried reseting and formatting all data off it
but still no luck
please help
csewell
Re: bv9500 pro saying is rooted in apps when it is not
Mon Aug 19, 2019 2:14 am
You may get that warning if the bootloader is unlocked, even if it isn't rooted. Do you get an Orange alert warning and a 5 second delay when starting? If not then the bootloader is locked and ok, and the problem lies elsewhere.
iceeci
Mon Aug 19, 2019 5:42 am
No orange alert or warnings,no delay but it seems to be a safety net problem
