Hello, I have a A8/max with Android 6.0.
Icône on the board multipli themselves alone. Sometimes there 5 icons from the same app. Of course I installed the app only once. The only thing I can do is to delete the data from laucher3. At that every icon appear only once but no more at the right place.  And a bit later, again some of the icons multiplied for no reasons.
Is it a way to avoid the multiplication?
When I cleaned the data and re-order the icons, there is a way to backup the layout?
Thanks for your help.
Jean
