blake
Connect To Hidden WiFi Network
Fri Aug 16, 2019 11:57 pm
Hi, guys—
Just got my Blackview 9600 and it looks and feels great. One issue I'm having is that I keep my WiFi routers from broadcasting. Usually there's a way to indicate that Android should try to connect to certain networks even if they're hidden/not broadcasting but I can't find that!
:geek:
frofa
Re: Connect To Hidden WiFi Network
Mon Aug 26, 2019 7:06 pm
blake wrote:
Hi, guys—
:geek:
Just below the list of found networks, there is an option "+ add network", try it there!
