DaywalkerL612
Disable fingerprint touch function?
Wed Aug 14, 2019 6:34 am
Is there any way to disable the fingerprint scanner being used as a button? I have an issue with constantly having the touch function activate while holding my phone and it is extremely annoying. Currently in the touch function list there are these options for the click, double click and long press:
Close
Back to the previous menu
Back to the desktop
Enter the recent task list
Take photo/video
Screen capture
Why is there no option for no operate like the shortcut button? If there is a way to do this can someone please help me? I really enjoy this phone aside from that button.
Tugacav
Re: Disable fingerprint touch function?
Wed Aug 14, 2019 11:26 am
I have set all to "Close" and the fingerprint sensor works as a fingerprint sensor only.
Cheers,
sigro
Fri Aug 16, 2019 11:53 am
If I select "close", the function is deactivated for me.
DaywalkerL612
Fri Aug 16, 2019 3:44 pm
When I select close any time I brush the button it closes whatever application or screen I have open.
DaywalkerL612
Fri Aug 16, 2019 3:47 pm
Sigro your idea worked once I selected close for all 3 functions. Thank you for the idea and advice.
Jasonbvpro
Fri Aug 16, 2019 11:19 pm
I went crazy figuring this out i had the same annoying problem uncheck the box : Unlock only when screen is on and choose close you may not need to do both but i did and it works
good luck
