cipazer
root or twrp
Tue Aug 13, 2019 2:28 pm
can 9700 be rooted
has anyone twrp for it ?
without rooting call recording is not working
csewell
Re: root or twrp
Tue Aug 13, 2019 2:40 pm
You don't need TWRP to root. The stock boot image is available. Unlock the bootloader (everything will be erased), install Magisk, patch the boot image, and flash it.
cipazer
Re: root or twrp
Tue Aug 13, 2019 4:15 pm
where is the boot image ?
csewell
Re: root or twrp
Tue Aug 13, 2019 4:56 pm
I saved the last OTA update and copied it out of that. But you will probably find all you need here:
https://4pda.ru/forum/index.php?act=idx
