cribblekris
More screen and Sound issues
Wed Aug 07, 2019 7:26 am
Sound volume varies continuously I see that this is a known problem. And then the display brightness changes continuously as well, even if automatic screen brightness is set to off.
Also, if you search in settings you will see wifi assit if you type wifi in the search bar but then when you select it that option is not available.
Really getting tired of this phone now
Re: More screen and Sound issues
Wed Aug 07, 2019 8:50 am
Hi, can you post a video about your problem? our tech is handling this issue now
BV6000
Wed Aug 14, 2019 7:02 pm
It happened to me too, with the first BV9600 Pro that I bought.
They had to exchange it for another BV9600 Pro.
I received a call and the sound started loudly, but after 2 seconds it was low
Other times upon receiving the call, the ringtone constantly rose and fell
Also when listening to music in the Music application and listening to it through the rear speaker, the volume goes up and down all the time
The same in the YouTube application
I recommend you make use of the guarantee and have it changed.
This is another recognized bug
That's why we want updates !!!!
Thu Aug 15, 2019 2:06 am
Thanks for your feedback, we are testing this now.
BV6000
Thu Aug 15, 2019 8:37 am
It's a shame because to process the warranty, I had to record a video, and I sent it to the seller, but since I was changing my phone several times, I can't find the video. If I find it, I'll upload it to youtube so you can see it
Tue Aug 20, 2019 3:25 am
Thanks a lot
BV6000
Thu Aug 22, 2019 5:43 pm
Thanks a lot
Did you receive the pm with the videos I sent you?
Tue Aug 27, 2019 5:51 am
Thanks a lot
Sorry, I didn't receive it yet
DanfosqBek
Tue Aug 27, 2019 4:09 pm
Thanks for the update.
What about those of us who ordered the pro version that had their order messed up because of the broken Onlineshop. Do I have to wait until September now to get my pro extension kit? Thats not "about a month more" wait as previously stated.
BV6000
Tue Aug 27, 2019 7:43 pm
i sed you a PM right now
