Mike20
Inaccurate sensor
Wed Aug 07, 2019 5:43 am
Hello
I opened a post office a few days ago and received an answer, but they did not fix the problem, and then asked two questions, but did not receive a reply.
My question is can this sensor I suppose it is the Magnitik sensor responsible for the position or alignment compass, spirit level, calibrate in Engeneer mode or is this problem fixed by a software update or is it a hardware problem?
If the latter point is the case, I would have to return the device.
Does this problem still have someone else?
Re: Inaccurate sensor
Wed Aug 07, 2019 6:26 am
Have you calibrated these sensors before?
Mike20
Wed Aug 07, 2019 6:36 am
Hello
The calibration in the compass app did not really help.
Although the app works but the horizontal orientation is missing by about 8 degrees is apparent from the spirit level app.
