Yamach
speaker on calls
Wed Aug 07, 2019 4:15 am
Hi. I have a BV9500 after the last update the speaker stopped working on. It only works at a low level, and the microphone's silence is activated by itself. is there any way to correct ?? for me it is very important
Re: speaker on calls
Wed Aug 07, 2019 9:16 am
Does it work well before you update? What is the software version now?
Yamach
Mon Aug 12, 2019 4:39 pm
yes. before everything worked perfect I have version v1.0_20190320_20190517-0041
Yamach
Mon Aug 12, 2019 4:40 pm
Yamach
Tue Aug 20, 2019 5:22 pm
Dear administrator, will you have any answers? I need to correct this problem
Wed Aug 21, 2019 2:28 am
Sorry for the delay, it's available for you to record a video and send it to my private email(I have sent you a PM, pls check it)
we can analyze your problem more accurate, and give you fast feedback.
Yamach
Sat Aug 24, 2019 5:47 am
Dear administrator, could I try to install the new ROM on my BV9500 to solve the problem? Could you give me the instructions to install it?
Sat Aug 24, 2019 6:05 am
Hi, you can ask our tech. team for ner ROM or instructions: suppoet01@blackview.hk
Yamach
Sun Sep 01, 2019 2:38 am
I wrote to the ROM technician and I DON'T answer could you help me?
Chuck78
Wed Apr 08, 2020 10:15 pm
I also have speaker problems with my BV9500.  They were incredibly loud when I first purchased the phone.  So loud that I believe it caused destruction of one of the speakers very quickly.
After that, I had to squeeze the back of the phone very firmly in my hands while holding the sides, and the 2nd speaker would come back on.  Now, I get nothing when squeezing it.
I also have problem with microphones not transmitting my voice on phone calls properly. the phone itself checks for updates and says that it is current, but I think it has always said that, only once shortly after purchasing did it actually find an update.  That has been close to 2 years.  BV9500
