ArchG
A20 Pro start up problem
Tue Aug 06, 2019 12:52 am
A20 Pro Start up problems
I have recently purchased a Blackview A20 Pro mobile phone for use in Australia. After installing Sim the phone recognises the network but when I dial out the phone display shows "calling" but there is no ring tone or connection to the called number. After disconnection if i send a message the SMS goes through to the called number instantly. Have tried 3 different SiMs with the same result . When I try the SIM in another phone it works correctly. This is also the 2nd A20 Pro that this is happened to as I sent the first one back thinking it was faulty
ArchG. Blackview A20 Pro user.
