VictorTafolla
Air quality sensor
Fri Aug 02, 2019 8:56 pm
I have a question of what this sensor actually is capable to measure, since the actual Readings ara just CO2 , but in publicity and videos it has other readings.
I'm wondering if we s a setup issue or its just limited to CO2??
Re: Air quality sensor
Tue Aug 06, 2019 2:31 am
Hi, the sensor only for air quality, The number of other components in the air cannot be specifically detected
VictorTafolla
Tue Aug 06, 2019 3:38 am
Thank you for the Infirmation, but the. The promotional video is wrong, since there it has an additional reading that says " organic matter" that's what makes me confused.
Neville
Tue Aug 06, 2019 5:59 am
Having used it,, the VOC sensor detects harmful gases, but only itemises the CO2 which - of course - is harmless...
R404a
Tue Aug 06, 2019 4:15 pm
it's more gadget than anything else I think, no ?
