Okami_Xci
Screenprotector question
Fri Aug 02, 2019 9:09 am
I have received a Blackview BV9700 Pro and I'm slightly confused now.
In the box, there is a "soft" screenprotector included, but if I look at my phone it seems there already is a screen-protector attached?
There was a layer on the phone with a pull-tab, and on that layer it was printed to have the device charge first.
After I removed that layer, It seemed there was already a screen protector on the phone because I could see a tiny airbubble trapped (which I managed to squeeze out)
Is this soft screenprotector supposed to be a replacement? or is this for over the one that is already on the phone?
Re: Screenprotector question
Fri Aug 02, 2019 9:24 am
Hi, BV9700 pro was pre-pasted a screen film, you don have to replace it
