novotnyt83
Root?
Fri Aug 02, 2019 5:58 am
Hi have been anyone succesfull with rooting? kingo root and towelroot does not work any other ideas?
yurnam38
Re: Root?
Sun Sep 08, 2019 12:33 pm
Yes, successfully ported TWRP with Hovateks auto porter and rooted with magisk :)
floraa
Re: Root?
Wed May 06, 2020 6:25 am
If you want to root your device, I recommend you use the king root application on your phone. This app has 100% success root rating.
nancysr
Re: Root?
Sat Feb 13, 2021 3:55 pm
Just use the latest version of the Kingo Root app on your phone.
JohnWick128
Re: Root?
Fri May 28, 2021 4:13 am
floraa wrote:
If you want to root your device, I recommend you use theking rootapplication on your phone. This app has 100% success root rating.
Is kingroot better than towelroot.
