schew
GPS is not working, NO SIGNAL
Fri Aug 02, 2019 2:36 am
My Blackview MAX 1 has no GPS signal at the outside open-air areas.
Why??? Is it the hardware issue???
Does anyone face the same issue?
GPS Test result is attached here -->
I look forward to hearing from you asap.
Thanks
Steve
novotnyt83
Re: GPS is not working, NO SIGNAL
Fri Aug 02, 2019 5:53 am
have the same problem very bad fix of gps in car it could not be used:-(
novotnyt83
Fri Aug 02, 2019 6:05 am
it could by fixed by mtk epo gps fixer, but this needs root.And kingo and other app does not work for me...
novotnyt83
Sun Aug 04, 2019 8:53 pm
seem it is not hardware problem but a-gps problem. it could by solved by root and mtk gps fixer. But i was unsucessfull with rooting phone.
schew
Sun Aug 04, 2019 11:47 pm
Anyone got any idea of the issue???
Andreiii
Mon Aug 05, 2019 7:50 pm
Hey!
Same problem here ... I tried several times to calibrate the compass bust still not working... I think is a software problem
Admin? How we solve this?Image
Tue Aug 06, 2019 7:03 am
Hi, guys, the GPS shrapnel is deflected, it needs to be clamped.
Dadasol
Mon Jul 20, 2020 10:31 pm
Make a video on how to fix the problem
Dadasol
Mon Jul 20, 2020 10:33 pm
novotnyt83
Sun Aug 23, 2020 8:42 am
ok, how do I clamp it? instructions?
