BloodyAltair
Kernel sources
Fri Aug 02, 2019 12:08 am
@Blackview, could you please provide the source code and kernel hooks for the Blackview BV6000s (MT6737T) device? As far as I understand, since Linux is licensed to LGPL, as the custom kernel distributor, you should provide the kernel source ( It would be great, if you can also supply `mkinicpio` script to build initd)
Thanks.
Re: Kernel sources
Fri Aug 02, 2019 3:25 am
Sorry, you have to buy source code and kernel hooks yourself
aryansnows
Re: Kernel sources
Fri Dec 11, 2020 7:26 pm
how to buy kernel source?
