wilczur
Dual sim active or standby?
Thu Aug 01, 2019 10:00 pm
I start using second card sim and i see that if i have active mobile data connection on second sim, on first one nobody can call me.
Is any way to accept phone calls when second sim has mobile data turn on? (If mobile data stops when first card answers call it be ok)
Any chances for that?
grAwp
Re: Dual sim active or standby?
Fri Aug 02, 2019 6:17 am
For me it works perfecty, data on one SIM turned on and with the second i can calling. Please ask to some friend to check the settings with your sim cards.
wilczur
Fri Aug 02, 2019 6:38 am
So you can download a file on one sim and answer call on second in the same time?
To precise: i can answer if mobile data is on, but no active downloading or something that using 3g/4g in that moment.
If I use internet browser , then if somebody call me in that moment, then he have info that i am not avaiable, and after few minutes i get sms that somebody try to call me.
