tomm81
BV9500 ROM
Thu Aug 01, 2019 1:41 pm
It would be possible to have new bv9500 ROM to directly update with SP Tools?
Thank you very much
Lolo976
Re: BV9500 ROM
Fri Aug 16, 2019 9:24 pm
Hi. Same question for the admin.
mous
Re: BV9500 ROM
Fri Aug 23, 2019 8:46 am
Hello. Same question for the administrator. AS WELL
Lolo976
Re: BV9500 ROM
Sun Sep 08, 2019 9:30 pm
Can we have an answer please?
mafa_mafa
Re: BV9500 ROM
Wed Sep 18, 2019 10:38 pm
I do not understand. What should I do? I don't want to ruin my cellphone. I'm a normal user, not a programmer. # Otherwise: The ZIP file cannot be updated normally, the BV9500 will reboot without the update effect. Why is it so complicated?
Parcheval
Re: BV9500 ROM
Tue Feb 04, 2020 5:40 pm
blackview_admin wrote:
Parcheval wrote:
When can we finally expect to get official BV9500 Firmware available for download?
We've been requesting it for more than one year... And been waiting for more than one year...
BV9500 PRO firmware look at the post: http://bbs.blackview.hk/viewtopic.php?f=241&t=532650
BV9500 firmware look at the post: http://bbs.blackview.hk/viewtopic.php?f=272&t=532359&p=855232#p855232
I am not sure which firmware version you need. You can judge by version date.
Thanks for your reply.
First of all, for BV9500, the last firmware available is from 2019051717, can we expect soon a newer one?
Then concerning the procedure:
For the BV6000 with "SP_Flash_Tool_v5.1716_Win" the procedure was to select "DOWNLOAD ONLY" and then there was the option to uncheck userdata in order to keep them and that the flashing doesn't overwrite them.
Where is such option for BV9500 with "SP_MDT_exe_v3.1836.00.01-A2018.11.06-v1.0-custom" https://mega.nz/#!Xb4GxICK!Ft18_QZHzlOV ... -Y9MhhUdd0 ? In the video for BV9700 Pro you indicated above, we can see at the very end that there is a DL(userdata) OK so I understand this overwrites the userdata so it is then needed to reinstall everything on the phone, which is obviously a long and annoying task...
Any solution to bypass this problem?
Re: BV9500 ROM
Wed Feb 05, 2020 4:22 am
Hi.
Sorry,  There is not newer one of BV9500 firmware.
The last two issues I really don’t understand. My former colleague in charge of the forum has left. :(
So I think you'd better contact our professional after-sales directly.
You can post the solutions in this post if you get the results.
Parcheval
Re: BV9500 ROM
Thu Feb 06, 2020 6:17 pm
No news from support.
However, you can proceed as follow:
1- Download latest SP Flash Tool from https://androidmtk.com/smart-phone-flash-tool
2- Select the Scatter file which is inside your ROM folder
3- Select DOWNLOAD ONLY and untick USERDATA if you don't want to overwrite them
4- Click on DOWNLOAD
5- Enable USB Debug mode on your phone
6- Turn OFF your phone
7- Connect your phone to the PC through USB
8- Once the process is finished successfully (green tick), unplug your phone and restart it, voilà, your phone is now updated!
Successfully tested with ROM 2019051717_s32v63c2k_jk for BV9500 with SP Flash Tool v5.1944 on Win10 1909
Ragheed88888
Re: BV9500 ROM
Fri Feb 07, 2020 2:32 am
Updated by using the ota file. but they didn't fix the multi touch & touch stuttering that people was talking about over and over , and they was saying (tracked a fix will came).... You are guys not professional .. the programming crew needed to be replaced
Or these is on the company itself
Next time dont give promises about it ok
