Rvaarle
Installed App Storage (APK)
Tue Jul 30, 2019 8:26 am
Good day, I have got a BV6000S and I have installed an App for work. The App works but I need to do some configuration on the App by importing a different configuration file to that that was installed on installation. The problem is that I'm unable to find the installation files on the "Internal Shared Storage", where can I find the installation files or how can I install the App that the installation files are on the Root (Internal Shared Storage)?
Regards
Rob
