Xorgeo
BV9700Pro USB Type-C jack
Mon Jul 29, 2019 11:51 am
Is the extended USB Type-C plug required by the BV9700Pro part of any standard?
None of my cables with a standard Type-C jack on them will not work because the Type-C jack on the BV9700Pro is recessed into the case.
Were can I find BV9700Pro accessories?
I would like to get more of the USB Type-C adapters that came with the phone.  (The short one that has the extended Type-C plug and a standard Type-C jack.)
I'm also looking for a "thin" and "narrow" (same or less wide than the phone) wireless charger.
BV9700 Pro
Re: BV9700Pro USB Type-C jack
Tue Jul 30, 2019 6:47 am
Hi, there; You can buy the Type c cable or Qi wireless charger on our global store
