grAwp
Problem after updates 20190614-1855 - cellular data
Mon Jul 29, 2019 4:41 am
After updates, if i click on Cellular data (in main top panel), not showig when the data is on or off. I must go in to Settings>Network and Internet>Data usage>Mobile Data - there i can only see when the data is on or off.
Has someone this bug after new update with main top panel ?
PLEASE FIX IT FAST!!!
Re: After updates 20190614-1855
Mon Jul 29, 2019 5:53 am
Hi, there; Our tech. team are fixing this and will release a new update soon
grAwp
Mon Jul 29, 2019 6:20 am
as other updates : "never" ?
:D
grAwp
Mon Jul 29, 2019 6:53 am
I tried many times but after update the cellular data didnt working.
FIX IT!!!
grAwp
Re: Problem after updates 20190614-1855 - cellular data
Tue Jul 30, 2019 5:45 am
Sorry but i am not an idiot. I have 4G signal but when i click on data not working internet.
Anyone else with this problem please?
grAwp
Tue Jul 30, 2019 6:08 am
The new update delete "Access point names" on your mobile network settings. You must manually (if not automatically supported from your provider) set this point names. Now for me internet working.
kontinent555
Tue Jul 30, 2019 11:49 am
My cellural data also do not working after last update. Please fix it fast!!! This phone I need for work!!! No possibility to get other now!!!
grAwp
Wed Jul 31, 2019 5:11 am
see my post.... there is a fix...
