FraeGuile
Question: BV9500 = BV9500 Pro?
Tue Jul 23, 2019 1:43 am
I have read the rules/guidelines for this forum. If I did not follow the rules/guidelines, please let me know. Thanks.
Hi!
So I just got my BV9500 today.
Looking on this forum, I found this one. I was wondering if the BV9500 is considered as the BV9500 Pro?
Thanks!
Re: Question: BV9500 = BV9500 Pro?
Tue Jul 23, 2019 2:39 am
BV9500 ≠ BV9500 pro
Click here to check to details of BV9500
Click here to check to details of BV9500 Pro
Tech Addict
Tue Jul 23, 2019 3:06 am
I've noticed also that there is no non-pro forum, only pro. Is there a reason for this?
FraeGuile
Tue Jul 23, 2019 3:18 am
blackview_admin wrote:
BV9500 ≠ BV9500 pro
I am sorry for the confusion in my post.
Let me rephrase my question:
I meant to ask if this forum (BV9500 Pro) is OK for posting about BV9500 and BV9500 Pro?
FraeGuile
Tue Jul 23, 2019 3:20 am
This is what I meant by my post!
I'm so sorry for the confusion!
Thanks for wording this better than me, Tech Addict! :)
Tue Jul 23, 2019 3:25 am
Thanks a lot for your kindness advice, we will add the part of BV9500 sonn :lol:
chrisostomul
Tue Jul 23, 2019 2:50 pm
Actually, if there is a problem with bv9500 pro (aside of walkie-talkie function) there is the same problem with bv9500. One has 2gb ram and 64 gb space more than the other(and the walkie-talkie). And depending of the system update you're on, different codes to access some hidden menus. Few months ago I flashed the "pro version" rom on my bv9500 (in a desperate try to find a fix for cell signal) and it worked fine.
Tech Addict
Thu Jul 25, 2019 3:15 am
I wondered if the non pro would run the pro ROM without issue. Good! And I assume you didn't discover it actually had the radio bits, just disabled in the non pro ROM? I would wonder if it actually would cost enough to include the one or two chips necessary that they would have them deliberately left out as I have seen features simply disabled in ROM before rather than omitted in hardware (for instance to permit import into certain locales). I had wondered if that may have been the case with the non pro.
chrisostomul
Mon Jul 29, 2019 11:35 am
Hi, I had a thought about this... It might worth a try. It seems, from what I could see, that you only need to find a way to mount the antenna (in a water-proof way) and where to solder the wires on motherboard. The app is there and opens but I could not test anything.
But then I also have two midland g7 pro that work on 0.5/3 watts AND a baofeng uv5-rtp (1/4/8 watts) so I won't spend too much time for such mod.
Tech Addict
Mon Jul 29, 2019 4:30 pm
Similar situation here, it was more than an idle curiosity to begin with but after buying a Baofeng UV-B5 I see how little use the BV's built-in really is. I wouldn't waste any time on it.
