mvdwege
NFC Tap & Pay does not work
Sat Jul 20, 2019 1:10 pm
I installed the Wallet app from my bank, which read my bank card without problems using the NFC reader, but when I want to use my 9700Pro to pay, I get zero reaction if I hold it up to the payment terminal, no matter which way I hold it. NFC is enabled, Tap & Pay mode is on, and the Wallet app is set to default.
On my older 9500Pro this works just fine.
Neville
Re: NFC Tap & Pay does not work
Mon Jul 22, 2019 9:59 am
Can confirm this doesn't work, as we are a Visa paywave merchant. The phone does not make Google wallet payments, and nor does card emulation mode work as a security element missing warning comes up. Don't know if the two issues are linked.
The NFC hardware is working in Android Beam mode.
Neville
Wed Jul 24, 2019 4:55 am
Admin...please can you pass this on to tech team for a bug fix....phone is currently non-compliant with Google certification on this issue. Needs addressing urgently.
Wed Jul 24, 2019 5:50 am
Hi, our technical team is trying to deal with this problem. We need you to provide us with your software version so we can send you corresponding software to verify NFC function
Neville
Wed Jul 24, 2019 9:53 am
Build number V1.0_20190510V5_20190620-2054
mvdwege
Thu Jul 25, 2019 6:34 am
Exact same build as Neville
Thu Jul 25, 2019 6:45 am
Our tech team is handling with this problem, OTA updates will be released next week to address this issue :)
VictorTafolla
Mon Jul 29, 2019 4:56 am
I have the same issue, my build number is Build number
BV9700Pro S41 V1.0.20190517V5h
Mon Jul 29, 2019 10:12 am
Hi, guys;
Our tech. team has solved this problem, and released a new version. You can update via OTA
VictorTafolla
Mon Jul 29, 2019 2:13 pm
I have no idea what I'm doing wrong, I had already installed the OTA update you mentioned.
