R4d0N
some questions
Sat Jul 30, 2016 4:17 pm
I have some questions about the BV6000.
Yesterday I received my mobile and peeled off the mask as it is told. Now it looks like there is already a
display protection on the display and I am confused about the delivered display protection mask in the box.
Do I have to put it on the display additionally to protect it, or is it replacement ?
How can I disable the vibration from push a key from the keyboard?
Furthermore I want to make a cutout from a picture as wallaper but it doesn´t work.
That's it for the moment... ;)
Thanks for answers!
Re: some questions
Mon Aug 01, 2016 7:09 am
R4d0N wrote:
Thanks for answers!
The addtional protection is replacement.
you can disable vibration via setting menu.
Best regards,
Admin
