[color=#2b2b2b][color=#337fe5][size=85]https://promo.blackview.hk/world-largest-screen-rugged-phone-bv6100/[/color][/size]
From the leaked design, specs and functions, Blackview’s new hit -- BV6100 would be one. It’s an ideal outdoor phone for many people. Except for one thing, it doesn’t cost enough. Considering its wide applications, it could be priced at $300, but actually you can buy it with no more than $200. Without further ado, let’s look at what occasions that it can be applied.
It’s IP68 & IP69K waterproof and MIL-STD-810G certified. BV6100 rises to the occasion for sure from outdoor sports, like surfing, rock climbing, to industrial environments like constructions sites. But BV6100 can do more.
Unlike traditional rugged phones, BV6100, with more stylish appearance, makes it a suitable phone for office, social occasions, and any decent occasions.
It has glass design on the front and the back, body thickness of only 11.5mm. Every part of the Blackview BV6100 is put together so well that the finished look is almost like mainstream smartphone in the market. It’s a nice, smart choice for office use.
It has a shortcut key for splitting screen for multitasking. This is so useful for office workers. This is sure to increase your work efficiency.
Now switch to the party scene. Want to play games with your pals? BV6100 6.88’’ ultra-large display lets you enjoy immersive game experience and give you an increased probability of winning.
And if you want to transmit photos to your friend’s phone. What methods would you like? Bluetooth? It’s troublesome for pairing. BV6100 has NFC-data transmission function, which can let you enjoy rapid transmission simply by touching the two phones and clicking the picture you want. That’s it. No pairing code is necessary to link up and because it uses chips that run on very low amounts of power (or passively, using even less), it's much more power-efficient than other wireless communication types.
Want to play bigger? Set fire on your phone, it turns out to be safe and sound when picked up. BV6100 has a tough exterior and can work normally from -30℃ to +60℃.
Think further, if you’re lost in a remote area, BV6100’s positioning still work well as it adopts GPS, Glonass, Beidou, Galileo 4 channels signals in coordination. It’s promised that the navigation accuracy is risen to an unprecedented level. It works well even in a condition where professional avigraph does not.
What if the phone runs out of power, you may think. Don’t worry, the phone comes with an industry-leading 5580mAh battery. Standby time up to 600h. Basically, the situation of power-off is nearly zero.
Let’s assume your friend’s phone runs out of electricity, then BV6100’s reverse charging function comes to function. You can lend some electricity to your friends, really. Just connect the two phones with an OTG cable, and BV6100 can act as a charging station and be used to charge your friend’s phone. I’m sure your friend will be so grateful for you.
