Vydka
Speaker sound problems
Tue Jul 16, 2019 2:23 pm
I recently bought 2 Blackview BV6000 phones and have same problem on both. During longer calls sometimes sound on microphone gets gradually lower to a point where you barely can hear. Usually if you drop the call and call again it gets better. Sometimes need to restart phone. Updated both, did factory reset - the same. What I noticed is that when it happens it's usually it switches to 3g network from 4g - don't know if it can be connected.
Any ideas? Is that a common issue? Any fix available? Or more troubleshooting? Getting close to a point where will need to return both and get different brand phones :(
Or is this same thing as with loudspeaker?
Re: Speaker sound problems
Thu Aug 22, 2019 8:07 am
This is because bad signal, 4G turns to 3G while the signal switches, you can consult your local carrier whether there is a problem with the base station
custal
Tue Sep 24, 2019 1:49 pm
Open the lid that hides the pressure sensor.
That usually does the trick.
