mtnman
I CAN'T HEAR CALLER THRU EAR SPEAKER!
Fri Jul 12, 2019 2:02 am
Suddenly, for no apparent reason, my phone, the bv8000pro simply stopped projecting sound through the ear speaker at a discernible volume, I can barely pick up the sound if I am in a very quiet room and I have tried everything that I could think of and that you suggested. This seems to be a common problem on this phone which I truly wish I had known before I spent almost $400 on a phone that was supposed to be indestructible virtually. I already went into engineer mode as suggested and changed receiver and speaker to 240 and nothing has happened, is there any way to fix this issue on this phone I bought from Amazon about a year ago? Please give me some help because I cannot spend another $400 on these phones, everything else works perfect and I am very pleased with it but now I cannot hear any callers unless I put it on speaker phone.Thank you for any assistance you can provide, I would really appreciate it and it would be a true blessing, again thank you.
Re: I CAN'T HEAR CALLER THRU EAR SPEAKER!
Fri Jul 12, 2019 9:55 am
Hi there! If your phone still runs under warranty, contacting the seller to have it replaced or repaired under warranty terms would be the best choice.
If your phone is not under warranty anymore, you'll have to open it and repair it by yourself (or contacting a 3rd party phone repair shop near where you live). In this case, here you can find the spare part: https://m.it.aliexpress.com/item/329637 ... 2925254659
