Genicoll
Wireless Charging
Thu Jul 11, 2019 7:19 pm
Hi, I have a 5 month old BV9500, with the latest updates, that doesn't want to charge on any wireless charge pads (tried 3 different makes). Using a cable is all fine and NFC works.
Anybody else have this issue or know of a fix?
Thanks!
Re: Wireless Charging
Fri Jul 12, 2019 9:47 am
Hi there! You'll need a Qi standard compatible charing pad. You can try our official one.
Tech Addict
Tue Jul 23, 2019 3:27 am
The one I bought at Target works for up to one amp charging. Paid five bucks for it in the dollar deals section.
However I don't know of any standard other than Qi, so I doubt spending more money on a fourth pad will net you any gains. Having had the phone apart a few times, there are a couple of spring loaded pin type contacts that connect the charging antenna coil to the charging board inside the phone. One of these pins is possibly not making good contact.
