after 10 minutes spent in the water my bv6800pro has a problem with battery power. there was a white smoke from the charging slot, and since then I did not charge the battery. I opened the phone and saw that the connectors on the label labeled E186014 4M were oxidized. Where can I get a new tile? I am from Croatia.
thank you
