Hello, i`m using the cell phone Bv 9500, i`ve bought it only 6 months ago. Is a very good phone, but the cell phone doesnt Charge as he should. If already tried different charging cables. to start the charging process i Need several tries to connect the cable. When the Batterie arrives at 15-20% or when i move a lot the cable the process stops. if think it`s a Problem with the charging port.
Best regards
Diddi O.
