timtim
Software problems with BV5800 Pro
Fri Jun 21, 2019 12:49 am
Hi
I have a BV5800Pro, bought in Germany 2 months ago.
All was good, but no the problem starts:
1. mobile data always looses connection. have to switch off and on the mobile data, then it works for 5 minutes...then off again.
2. the cell phone restarts a few times per day, on its own. I do not initiate the restart.
3. Apps like chrome, messenger, whatsapp just shut down in the middle of using them.
4. Very high battery consumption. 3 minutes chat in messenger uses 1% battery life.
can someone help?
regards
Tim
Re: Software problems with BV5800 Pro
Fri Jun 21, 2019 9:34 am
Hi there! First thing to do is performing a factory reset following this tutorial:
http://bbs.blackview.hk/viewtopic.php?f=192&t=334922
After that, don't load any previous backup when Google asks for it, just start from scratch.
Then report back if such issues are still there. ;)
timtim
Sun Jun 23, 2019 10:33 pm
Hello
thank you very much, it worked. Its all good now.
How can I avoid the same malefunction in future?
regards
Tim
Mon Jun 24, 2019 8:24 pm
timtim wrote:
Hello
regards
Tim
Disabling duraspeed may help. Avoiding installing too intrusive apps may help as well.
