dario
low quality photo in BV 9500Pro
Thu Jun 20, 2019 1:39 pm
despite  the settings put in App options(16M(16:9), ZSD on etc...)   the images taken appear very blurred (especially in case of lack of light).
There is some adjustement "out" of the App that I don't know or there is some patch to install to better the final result?
Thanks in advance for the support
Re: low quality photo in BV 9500Pro
Fri Jun 21, 2019 10:14 am
Hi there!
First, please perform a factory reset following this tutorial:
http://bbs.blackview.hk/viewtopic.php?f=192&t=334922
Second, please install the Opencamera App, definitely better than the stock one.
Set it to the native camera resolution, image quality 100%, ISO 100. ;)
Tech Addict
Fri Jun 21, 2019 10:57 am
I second everything admin said except maybe ISO. ISO 100 will require a well lit shot (read: outdoors in the sun), as you've already stated the camera doesn't work well in the more poorly lit shots (something others among us have complained about as well). I'd leave the ISO at Auto at first and then start working it down until the exposure starts getting too dark, them bring it back up a notch to lighten the exposure to "normal".
But no matter what you do, hardware is hardware, and the camera on this phone is no Canon 7D Mark IV.
I've taken better shots (even though at lower resolution) with a Kodak point and shoot made in 2004, but it had better lenses and a larger sensor, and a dedicated processor for the task.
Fri Jun 21, 2019 11:06 am
and i second back to you! ;)
dario
Sun Jun 23, 2019 7:13 pm
Hi to all,
thanks for the suggestions : when I have to reset the phone this means that I'll lose all the adjustements/bug corrections in the meanwhile done?
... for sure I don't expect to take photos like my Nikon D700 but at least more-or-less as an LG Q6 hopefully  ;)
beside Tech-admin guys, one special thanks to tech-addict, whose suggestions are as usual very precious for me
Bye
Sun Jun 23, 2019 10:28 pm
dario wrote:
Hi to all,
Bye
A factory reset will erase all your apps, photos, settings and so on. Bug corrections and latest firmware will be kept!
Tech Addict
Mon Jun 24, 2019 2:30 am
dario wrote:
Hi to all,
Good luck with that. I'm not sure what the Q6 quality is like but my LG G5 has a far superior API, if not hardware, to the BV9500. Being able to manually set focus, ISO, etc. makes A HUGE DIFFERENCE in taking photos and the BV9500 just can't hold a candle to the G5.
Bye
I very much appreciate the special mention, and I'm glad my suggestions are useful. I'm just an end user though, not an engineer... So be careful to recognize that what I suggest is just from what I've learned through experience and I can be - and have been, and will again be - wrong.
But I'm glad to be of any service or help I can be, and you are certainly welcome!
